What might cause the services to stop as the machine restarts?I�??m wondering why the services stop as the machine restarts. Sometimes, we are forced to restart the server machine which affects the services to stop[ATTACH=CONFIG]29809[/ATTACH]What might be the issue here?Thank youBestJamal
Hello Jamal,If you restart the machine, the services will stop. It will also take some time for them to come up. You can see the services as 'arcsoc.exe' in the task manager listed running under the Arcgis Server Service account. Unless you can give a little more detail as to what the problem is, I would say that this sounds like it could be expected behavior. Please let me know if I can assist you any further. Thanks-Justin
Many thanks Nidhin and Justin for the help,1. The �??start up type�?� of the ArcGIS Server is �??Automatic Delayed Start�?�[ATTACH=CONFIG]29832[/ATTACH]2. I couldn�??t figure out from where to check the �??Restart this service automatically whenever ArcGIS Server restarts�?� option3. If the reboot cause the services to stop then how much time do the services need to come up? Or do we still need to start them manually?I noticed that, sometimes, if I reboot the machine for the second time then services comes up started. Is this an expected behavior?
Hello again,Automatic Delayed Start is the default setting, and should be fine. I am not sure why you would need to start the service again. I suspect everything is working fine, but it is hard for me to say for sure. May I ask why you are rebooting your server so often? It seems like that is a strange workflow for an enterprise product. Is there any way you can simply not reboot as often? The reason I ask is, simply restarting the service once after reboot only takes a few seconds. If you can reduce the amount of reboots, the issue might not be that big of a deal to begin with. What operating system are you using? Thank you very much-Justin
You can find it in 'Map Service Properties'.
What might cause the services to stop as the machine restarts?Jamal
Good question Jamal.It happens to us occasionally. In my environment, I have several virtual machines at play with one single map service. SDE, Web Server, ArcGIS Server(s). When it happens to us, my guess is that it is a result of server patching and not starting the virtual machines up in the correct order.If your environment is distributed, then start the database, then ArcGIS Server(s) then your web server.If your environment is all on a single server, then I would ask whoever manages your servers what they did recently. Very rarely we have problems with the SDE machine where the SQL Server service starts, but not the Agent (and that is bad because backups don't run). I suspect that problem is related to all of the server monitoring software that our data center installs, but I can't prove it.
If you're able to connect to AGS in ArcCatalog or in Server Manager alright (which, from your screenshots it appears as such), then in my mind the "SOM" or the ArcGIS Server service is running just fine. That being said, I think the only reason a service might stop or never start is if there is an issue connecting to the underlying data sources. Since your data sources are file geodatabases local to the server, it's hard to believe that would be an issue but you never know. Can you check your ArcGIS Server log to see if there are any errors that might point to an issue? Can you also check your Windows Event Viewer for problems right after the machine boots up?
I don't think anyone really knows; hence the length of this thread. I will reiterate my questions...Can you check your ArcGIS Server log to see if there are any errors that might point to an issue? Can you also check your Windows Event Viewer for problems right after the machine boots up?
Thanks WilliamI�??ll be checking the logs of ArcGIS Server and Windows the next time I get this problem[ATTACH=CONFIG]29901[/ATTACH]
From the looks of your screenshot for ArcGIS Server Manager, you will most likely need to change the logging level filter to ERROR or somehting more granular to see the issues. Make sure you've set the logging level to actually record at ERROR level or better. Good luck!
Can you check c:\arcgisserver\logs\JAMAL-SONY\errorreports to see if an error report was produced per the messages in the log?
At this point, I'm at a bit of a loss. On reboot when the services are stopped, what happens if you try to start them all manually via ArcCatalog? Also, how many CPU cores on your machine and how much RAM? What are the min and max SOC instances for your services?
Jamal,Can you change the minimum number of instances to 0 on each of the Map Service, and observe the Map Service after reboot.
