def main(): import arcpy # assume data is available as point featureclass # and fc has projected coordinate system fc = "c:/folder/yourGeodatabase.gdb/yourFCname" # change this (path to featureclass GPS points) fldDistance = "DistGPSpoints" # change this (output name distance field) # add distance field if it doesn't exist if FieldExist(fc,fldDistance) == False: arcpy.AddField_management(fc, fldDistance, "DOUBLE") # Create update cursor for feature class fields = ['SHAPE@XY', fldDistance] with arcpy.da.UpdateCursor(fc, fields) as cursor: X = 0 Y = 0 cnt = 0 for row in cursor: cnt+=1 prevX = X prevY = Y X = row[0][0] Y = row[0][1] if cnt == 1: # for first point distance is 0 distance = 0 else: distance = getDist(X,Y,prevX,prevY) # Update row row[1] = distance cursor.updateRow(row) del row def getDist(X1,Y1,X2,Y2): import math return math.hypot(X2 - X1, Y2 - Y1) def FieldExist(featureclass, fieldname): import arcpy fieldList = arcpy.ListFields(featureclass, fieldname) fieldCount = len(fieldList) if (fieldCount == 1): return True else: return False if __name__ == '__main__': main()
