Are you getting the results in updateStateDD function?.And in result attributes are you getting the single field only.?
Try this.[HTML]<select name="selectFilter" id="mySelectControl" dojotype="dijit.form.Select"> </select>[/HTML] var selectControl= dijit.byId("mySelectControl"); if (this.fieldValues!= null && this.fieldValues.length > 0) { selectControl.addOption({ disabled: false, label: "- Values-", selected: true, value: "- Values-" }); for (icnt = 0; icnt < this.fieldValues.length; icnt++) { selectControl.addOption( { disabled: false, label: this.fieldValues[icnt], selected: false, value: this.fieldValues[icnt] }); } }
dojo.provide("com.esri.solutions.jsviewer.widgets.DemoWidget"); dojo.require("com.esri.solutions.jsviewer._BaseWidget"); dojo.require("com.esri.solutions.jsviewer._MapGraphicsMaintainer"); dojo.require("dojo.i18n"); dojo.requireLocalization("com.esri.solutions.jsviewer.widgets", "DemoWidgetStrings"); dojo.require("dijit.form.Button"); dojo.require("dijit.form.ComboBox"); dojo.require("esri.tasks.query"); dojo.declare( "com.esri.solutions.jsviewer.widgets.DemoWidget", [com.esri.solutions.jsviewer._BaseWidget, com.esri.solutions.jsviewer._MapGraphicsMaintainer], { url: "", fields:"", query:"", zoomScale:"" _module: "com.esri.solutions.jsviewer.widgets", templatePath: dojo.moduleUrl("com.esri.solutions.jsviewer.widgets", "templates/DemoWidget.html"), i18nStrings: null, postMixInProperties: function() { this.inherited(arguments); if (this.configData) { var L=this.configData.demo; this.url = L.layer; this.fields=L.fields; this.query=L.query; this.zoomScale = L.zoomScale; } this.i18nStrings = dojo.i18n.getLocalization( this._module, "DemoWidgetStrings"); }, postCreate: function(){ this.inherited(arguments); dojo.parser.parse(this.domNode); }, startup: function() { try { this.inherited(arguments); if (this._initialized) { return; } this.getAllNamedChildDijits(); this.init(); this.connects.push( dojo.connect(this.widgets.btnRecenter, "onClick", this, "onRecenter")); this._initialized = true; } catch (err) { console.error("DemoWidget::startup", err); } this.init(); }, onRecenter: function() { var p = new esri.geometry.Point(-118.24799,33.975004); this.map.centerAt(p); }, init: function() { //Query task to populate dropdown list with country names*/ try { if (this.url) { this.setMessage(this.i18nStrings.msgLoad, true); this.clearResults(); var url=this.url; stateQueryTask = new esri.tasks.QueryTask(url); stateQuery = new esri.tasks.Query(); stateQuery.returnGeometry = false; stateQuery.outFields = this.fields; stateQuery.where = this.query; stateQueryTask.execute(stateQuery,updateStateDD) } } catch (err) { console.error("DemoWidget::init", err); } } , updateStateDD: function(results) { try{ var stateNames = new Array(); var selectObj = document.getElementById("countrySearch"); selectObj.options.length = 0; var optObj = new Option("Choose a country"); selectObj.options[selectObj.options.length]=optObj; for (var i=0, len=results.features.length; i<len; i++) { var featureAttributes = results.features.attributes; for (attribute in featureAttributes) { var index = stateNames.indexOf(featureAttributes.country); if(index == -1) { stateNames.push(featureAttributes.country) } } } } catch (err) { console.error("DemoWidget::updateStateDD", err); } }, } );
