fromJSON () method public static function fromJSON(json:String):FeatureSetConvert from JSON to FeatureSet.Parameters json:String â?? ArcGIS JSON StringReturns FeatureSet â?? a new FeatureSetSee also Input JSON should match this REST response syntax
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"> <s:layout> <s:VerticalLayout paddingBottom="6"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import mx.collections.ArrayCollection; import mx.utils.StringUtil; private var jsonFeatureSet:String = ""; /** * Listen map mouse down handler */ protected function myMap_mapMouseDownHandler(event:MapMouseEvent):void { //var grGeometry:MapPoint = myMap.extent.center; var grGeometry:MapPoint = event.mapPoint; var grAttributes:Object = new Object(); var dateAttr:Date = new Date(); grAttributes.creationDate = dateAttr; var numberAttr:Number = 777; grAttributes.n = numberAttr; var boolAttr:Boolean = true; grAttributes.b = boolAttr; var stringAttr:String = "Text"; grAttributes.s = stringAttr; var gr:Graphic = new Graphic(grGeometry, sms, grAttributes); gr.toolTip = mx.utils.StringUtil.substitute("{0}\n{1}\n{2}\n{3}", gr.attributes.creationDate, gr.attributes.n, gr.attributes.b, gr.attributes.s); var grId:String = myGraphicsLayer.add(gr); trace(StringUtil.substitute("Graphic with id: {0} added.", grId)); } /** * Listen export button click handler */ protected function btnExportClick(event:MouseEvent):void { var arrGraphics:ArrayCollection = myGraphicsLayer.graphicProvider as ArrayCollection; if (arrGraphics != null && arrGraphics.length > 0) { var fsToExport:FeatureSet = new FeatureSet(arrGraphics.toArray()); fsToExport.geometryType = Geometry.MAPPOINT; if (fsToExport != null) { jsonFeatureSet = fsToExport.toJSON(); trace(jsonFeatureSet); } } } /** * Listen import button click handler */ protected function btnImportClick(event:MouseEvent):void { if (jsonFeatureSet != null && jsonFeatureSet.length > 0) { var fsImported:FeatureSet = FeatureSet.fromJSON(jsonFeatureSet); if (fsImported != null) { var arrImported:Array = fsImported.features as Array; myGraphicsLayer.graphicProvider = arrImported; } } } /** * Listen clear all button click handler */ protected function btnClearClick(event:MouseEvent):void { myGraphicsLayer.clear(); } ]]> </fx:Script> <fx:Declarations> <!-- Symbol for all point shapes --> <esri:SimpleMarkerSymbol id="sms" color="0x00FF00" size="12" style="{SimpleMarkerSymbol.STYLE_DIAMOND}"/> </fx:Declarations> <esri:Map id="myMap" mapMouseDown="myMap_mapMouseDownHandler(event)" level="3" wrapAround180="true"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" symbol="{sms}"/> </esri:Map> <s:Button id="btnExport" label="Export to JSON string" click="btnExportClick(event)"/> <s:Button id="btnClearAll" label="Clear all graphics" click="btnClearClick(event)"/> <s:Button id="btnImport" label="Import from JSON string" click="btnImportClick(event)"/> </s:Application>
var pFeatureSet:FeatureSet = null; var pFeatureSet2:FeatureSet = null; var arrGraphics:Array = new Array(); var pGraphic:Graphic; //Store all Graphics in an Array for (var i:int = 0; i < graphicsLayer.numGraphics; i++) { pGraphic = Graphic(graphicsLayer.getChildAt(i)); arrGraphics.push(pGraphic); } //Create FeatureSet pFeatureSet = new FeatureSet(arrGraphics); //to JSON var strJSON:String = pFeatureSet.toJSON(); //toFeatureSet pFeatureSet2 = FeatureSet.fromJSON(strJSON); //All graphics, but no geometries or symbols //Now with your example strJSON = '{"features" : [{"geometry" : {"x" : -178.24479999999991,"y" : 50.012500000000045},"attributes" : {"objectid" : 3745682,"datetime" : 1272210710000,"depth" : 31.100000000000001,"eqid" : "2010vma5","latitude" : 50.012500000000003,"longitude" : -178.2448,"magnitude" : 4.7999999999999998,"numstations" : 112,"region" : "Andreanof Islands, Aleutian Islands, Alaska","source" : "us","version" : "Q"}},{"geometry" : {"x" : -72.865099999999927,"y" : -37.486599999999953},"attributes" : {"objectid" : 3745685,"datetime" : 1272210142999,"depth" : 40.600000000000001,"eqid" : "2010vma4","latitude" : -37.486600000000003,"longitude" : -72.865099999999998,"magnitude" : 4.9000000000000004,"numstations" : 58,"region" : "Bio-Bio, Chile","source" : "us","version" : "7"}}] }'; pFeatureSet2 = FeatureSet.fromJSON(strJSON); //All graphics, but no geometries or symbols
FeatureSet () Constructorpublic function FeatureSet(features:Array = null)
features property features:ArrayArray of graphic features....See alsocom.esri.ags.Graphic
"features" : [ { "geometry" : { "x" : -178.24479999999991, "y" : 50.012500000000045 }, "attributes" : { "objectid" : 3745682, "datetime" : 1272210710000, "depth" : 31.100000000000001, "eqid" : "2010vma5", "latitude" : 50.012500000000003, "longitude" : -178.2448, "magnitude" : 4.7999999999999998, "numstations" : 112, "region" : "Andreanof Islands, Aleutian Islands, Alaska", "source" : "us", "version" : "Q" } }, { "geometry" : { "x" : -72.865099999999927, "y" : -37.486599999999953 }, "attributes" : { "objectid" : 3745685, "datetime" : 1272210142999, "depth" : 40.600000000000001, "eqid" : "2010vma4", "latitude" : -37.486600000000003, "longitude" : -72.865099999999998, "magnitude" : 4.9000000000000004, "numstations" : 58, "region" : "Bio-Bio, Chile", "source" : "us", "version" : "7" } } ]
toJSON () method public function toJSON():String
