I want to use ArcGIS REST Service as a ArcGISDynamicService in 4.0 beta. Any one tried this in 4.0 beta version.?
It works, also if ArcGISDynamicLayer class is not documented yet.
Try this:
require([
"esri/Map",
"esri/views/SceneView",
"esri/layers/ArcGISDynamicLayer",
"dojo/domReady!"
], function (Map, SceneView, ArcGISDynamicLayer) {
//Create map
map = new Map({
basemap: "hybrid"
//Create SceneView
view = new SceneView({
map: map,
container: "viewDiv",
camera: {
position: [7.654, 45.919, 5183],
tilt: 80
map.add(new ArcGISDynamicLayer("http://.../MapServer") );
I was not able to use indetify instead, it seems that the IdentifyParameters class is not already supported.
Davide
Thank you David, It is working fine, Also I want to know whether we can use digit.toolbar in this version?
You are welcome.
digit.toolbar is dojo, not esri api, so i think you should not have problems using it.
It looks as though this only currently works in 3D mode, not 2D - is that correct?
Thanks!
Yes Roland Martin, I tried many ways in 2D. It is not working. Hope this will work in only 3D..
