#import required modules import arcpy from arcpy import env #specify workspace env.workspace = "C:/Columbus_OH_LiDAR_2011/Canopy.gdb" #specify source geometry points = "C:/Columbus_OH_LiDAR_2011/Canopy.gdb/Extract_BS868661" #create comparison geometry feature class ind_trees = arcpy.CreateFeatureclass_management(env.workspace, "ind_trees", "POINT", points, "DISABLED", "SAME_AS_TEMPLATE", points) #find nearest features arcpy.Near_analysis(points, ind_trees) #create update cursor Ucur = arcpy.updateCursor(points, "", "", "", "HEIGHT D") #declare variable used to assign tree ID number x = 0 for row_u in Ucur: #tree ID assigned where no near feature was found within search radius if row_u.NEAR_DIST > row_u.HEIGHT / 4: row_u.TREE_NUM = x Ucur.updateRow(row_u) x = x + 1 #assign tree ID from near feature else: Scur = arcpy.SearchCursor(ind_trees) for row_s in Scur: if row_s.OBJECTID == row_u.NEAR_FID: row_u.TREE_NUM = row_s.TREE_NUM Ucur.updateRow(row_u) del row_s del Scur #insert a copy of current update cursor row object to comparison geometry feature class Icur = arcpy.InsertCursor(ind_trees) Nrow = Icur.newRow() Nrow.Shape = row_u.Shape Nrow.PointCount = row_u.PointCount Nrow.ORIG_FID = row_u.ORIG_FID Nrow.Z = row_u.Z Nrow.RASTERVALU = row_u.RASTERVALU Nrow.HEIGHT = row_u.HEIGHT Nrow.TREE_NUM = row_u.TREE_NUM Nrow.NEAR_FID = row_u.NEAR_FID Nrow.NEAR_DIST = row_u.NEAR_DIST Icur.insertRow(Nrow) del Icur del row_u del Ucur
#import required modules import arcpy from arcpy import env #specify workspace env.workspace = "C:/Columbus_OH_LiDAR_2011/Canopy.gdb" #specify source geometry points = "C:/Columbus_OH_LiDAR_2011/Canopy.gdb/Extract_BS868661" #create comparison geometry feature class ind_trees = arcpy.CreateFeatureclass_management(env.workspace, "ind_trees", "POINT", points, "DISABLED", "SAME_AS_TEMPLATE", points) #declare variable used to assign tree ID number x = 0 sCur2=arcpy.SearchCursor(points, "", "", "", "HEIGHT D") #get nearest for each point for row in Scur2: #Create feature layer for current point: arcpy.MakeFeatureLayer_management(points, "TargetPoint_lyr", '"FID" = '+str(row.FID)) #find nearest feature within a search distance (for current point only) arcpy.Near_analysis("TargetPoint_lyr", ind_trees, row.HEIGHT / 4) del row del Scur2 #create update cursor Ucur = arcpy.updateCursor(points, "", "", "", "HEIGHT D") for row_u in Ucur: #tree ID assigned where no near feature was found if row_u.NEAR_FID == -1: row_u.TREE_NUM = x Ucur.updateRow(row_u) x = x + 1 #assign tree ID from near feature else: Scur = arcpy.SearchCursor(ind_trees) for row_s in Scur: if row_s.OBJECTID == row_u.NEAR_FID: row_u.TREE_NUM = row_s.TREE_NUM Ucur.updateRow(row_u) del row_s del Scur #insert a copy of current update cursor row object to comparison geometry feature class Icur = arcpy.InsertCursor(ind_trees) Nrow = Icur.newRow() Nrow.Shape = row_u.Shape Nrow.PointCount = row_u.PointCount Nrow.ORIG_FID = row_u.ORIG_FID Nrow.Z = row_u.Z Nrow.RASTERVALU = row_u.RASTERVALU Nrow.HEIGHT = row_u.HEIGHT Nrow.TREE_NUM = row_u.TREE_NUM Nrow.NEAR_FID = row_u.NEAR_FID Nrow.NEAR_DIST = row_u.NEAR_DIST Icur.insertRow(Nrow) del Icur del row_u del Ucur
