U can get your model from 3dwarehouse.com
After that u can put it into ArcGIS
You are aware that you will loose all georeferencing information once you import into ArcScene? (Unless your starting point was a multipatch feature which you have exported, modified in SketchUp, and want to replace with the updated model)The technique you described should have worked for exporting to Google Earth. How complex is your model?
My next step is to import my model into ArcGIS. But I need to verify/review my model in GoogleEarth before I start the importing. Sending back a model to GoogleEarth for quality control is a part of the whole process and I am sure some people experienced the same issue as I mentioned in my first post. Any help is appreciated.
