I guess it is likely ArcCatalog tried both Oracle clients (10g and 11g)
ArcGIS simply makes the call to the Oracle client which would be the first one in the library path as the DLL is loaded.
[INDENT]System PATH SDE direct connect string Result 10g path;11g path sde:oracle10g Connection Succeeded 10g path;11g path sde:oracle11g Connection Succeeded 11g path;10g path sde:oracle10g Connection Succeeded 11g path;10g path sde:oracle11g Connection Succeeded 10g path sde:oracle10g Connection Succeeded 10g path sde:oracle11g Failed: Server library could not be loaded 11g path sde:oracle10g Failed: Server library could not be loaded 11g path sde:oracle11g Connection Succeeded[/INDENT]
