- Access of possibly undefined property id through a reference with static type com.esri.ags.layers.supportClasses:layerInfo - Access of undefined property JSON - Can not resolve a multiname reference unambiguously. JSON
* MAJOR CHANGE when a layer of a map service or the whole mapservice is excluded using the excludelayers it is excluded from the TOC and the map. This has changed from where it use to be visible in the map even though it was excluded from the TOC. *Clarification* If you want to exclude a whole map service from the toc and the map then you just remove it from the viewers main config. Currently if you exclude a map service and do not specify any sublayers then the mapservice will remain in the map.
