How can I launch a calcite modal directly in javascript ? I want to launch programmatically these modals (Calcite Web | Esri Design Patterns ) as example.
Where can I found documentation about that ?
Jérôme.
The JavaScript section of the docs touches on this.
Scroll down and you can see the options for the Modal events in the tables.
You need to import the event bus and then you can emit the modal event with a modal id to open and close the modals programmatically.
<SPAN class="keyword token">import</SPAN> <SPAN class="punctuation token">{</SPAN> bus <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">from</SPAN> 'calcite<SPAN class="operator token">-</SPAN>web`<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Opens a modal specified by data-modal attribute</SPAN> bus<SPAN class="punctuation token">.</SPAN><SPAN class="token function">emit</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'modal:open'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>id<SPAN class="punctuation token">:</SPAN> modalId<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Closes open modal</SPAN> bus<SPAN class="punctuation token">.</SPAN><SPAN class="token function">emit</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'modal:close'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks for your answer Rene.
For anyone coming across this, it looks like the approach has changed. calcite-modal has an "active" property, and I believe this is used to show the modal.
"calcite-web" is deprecated, at least that's what noted here https://github.com/Esri/calcite-web. That removes the bus referred to in the solution to the original question.
I haven't yet confirmed that the "active" property is the way to go, still working
You're right. The active property sets the modal visibility (fade in or fade out).
// show modal document.querySelector('calcite-modal#<modal ID>').active = true; // hide modal document.querySelector('calcite-modal#<modal ID>').active = false;
The modal ID is optional, or you can just use the ID as the selector.
