outputShapefile= os.path.splitext(inRaster)[0] + "_thr" + str(i) + "_" + str(minHa).replace('.','p') + "ha.shp" whereClause = '"Area_ha" >=' + minHa waterSql = '"Value" > 0 AND "Value" <=' + int(i) # Process: Con (needs spatial analyst license) outCon = Con(inRaster, 1, 0 , waterSql) outCon.save("outCon") arcpy.AddMessage("Open flood extent map is created (raster)") # Process: Focal Statistics (5x5 Mode) outFocalStats = FocalStatistics(outCon, "Rectangle 5 5 CELL", "MAJORITY", "DATA") outFocalStats.save("outFocalStats") arcpy.AddMessage("Image is filtered") # Process: Convert Raster to Polygon arcpy.RasterToPolygon_conversion(outFocalStats, "Raster2poly.shp", "NO_SIMPLIFY", "") arcpy.AddMessage("Converted to vector") # Process: Select Gridcode >0 arcpy.Select_analysis("Raster2poly.shp", "Raster2polyCode0.shp", "GRIDCODE >0") # Process: Add Field to Calculate Area arcpy.AddField_management("Raster2polyCode0.shp", "Area_ha", "FLOAT", "", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "") # Process: Calculate Field: Area in Ha arcpy.CalculateField_management("Raster2polyCode0.shp", "Area_ha", "!Shape!.area/10000", "PYTHON_9.3", "") arcpy.AddMessage("Area calculated (ha) for flooded polygons") # Process: Select min polygon size arcpy.Select_analysis("Raster2polyCode0.shp", outputShapefile, whereClause) arcpy.AddMessage("Applying the minimum hectare size") # Process: Delete intermediate files arcpy.Delete_management("outCon", "") arcpy.Delete_management("outFocalStats", "") arcpy.Delete_management("Raster2poly.shp", "") arcpy.Delete_management("Raster2polyCode0.shp", "") arcpy.AddMessage("Intermediate files deleted")
edit your original post and throw the script within code blocks (the # symbol in the html editor)
