Can GeoEvent delete related features? I have a feature service that contains all the cases, open and close cases. All the open cases will create buffers and when the case status is changed from Open to Closed, I want to buffers to be removed. I do not want to remove the Closed cases from the feature service only the buffer. Update a Feature output updates the features which is useful when the fields are edited but it does not remove the features that do not meet the filter criteria as such the cases that has been closed will still be in the there and this will effect the model as the buffer will used as GeoFence.
