ArcGISLocalFeatureLayer MyFeatureLayer; MapPoint pnt;//initialize it with your favorite coordinate... �?� Private void EditMyFeatureLayer() { LocalFeatureService localFeatureService = new LocalFeatureService(@C:\Data\MyData.mpk); MyFeatureLayer = new ArcGISLocalFeatureLayer(localFeatureService,0); MyFeatureLayer.ID = "Cars"; MyFeatureLayer.Visible = false; MyFeatureLayer.Editable = true; MyFeatureLayer.DisableClientCaching = true; MyFeatureLayer.ValidateEdits = true; MyFeatureLayer.Mode = FeatureLayer.QueryMode.Snapshot; MyFeatureLayer.AutoSave = true; MyFeatureLayer.OutFields.Add("*"); MyFeatureLayer.Where = "Car_id = 1"; MyFeatureLayer.Initialized += new EventHandler<EventArgs>(MyFeatureLayer_Initialized); MyFeatureLayer.UpdateCompleted += new EventHandler(MyFeatureLayer_UpdateCompleted); MyFeatureLayer.Initialize(); } void MyFeatureLayer_Initialized(object sender, EventArgs e) { MyFeatureLayer.Update(); } void MyFeatureLayer_UpdateCompleted(object sender, EventArgs e) { //update here�?� foreach (Graphic g in MyFeatureLayer.Graphics) { g.geometry = pnt; } }
//put your code in ThreadProc method... Thread t = new Thread(ThreadProc); t.SetApartmentState(ApartmentState.STA); t.Start();
public class Program { FeatureLayer myFeatureLayer; static void Main(string[] args) { Thread t = new Thread(new ThreadStart(ThreadProc)); t.SetApartmentState(ApartmentState.STA); t.Start(); Console.ReadLine(); } public static void ThreadProc() { string url = "myURL"; Program p = new Program(); p.UpdateLayer(url); } private void UpdateLayer(string Url) { myFeatureLayer = new FeatureLayer { Url = Url, ID = "23", Mode = FeatureLayer.QueryMode.Snapshot, }; myFeatureLayer.Initialized += (sender, eventArgs) => { myFeatureLayer.Update(); }; myFeatureLayer.InitializationFailed += (sender, e) => { Console.WriteLine(myFeatureLayer.InitializationFailure.Message); }; myFeatureLayer.UpdateFailed += (sender, e) => { Console.WriteLine(e.Error); }; myFeatureLayer.UpdateCompleted += (sender, e) => { myFeatureLayer.Graphics[0].Attributes["NAMNEDIT"] = "Test"; myFeatureLayer.SaveEditsFailed += (a, b) => { Console.WriteLine(b.Error); }; myFeatureLayer.SaveEdits(); }; myFeatureLayer.Initialize(); } }
var syncCtx = new DispatcherSynchronizationContext(); SynchronizationContext.SetSynchronizationContext(syncCtx);
using System; using System.Threading; using System.Windows.Threading; using ESRI.ArcGIS.Client; namespace UpdateGraphicsConsole { class Program { static string _url = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0"; // Make sure the main thread is an STA thread [STAThread] static void Main(string[] args) { // For some reason the SynchronizationContext of the main thread is null. // Create and set a new DispatcherSynchronizationContext. var syncCtx = new DispatcherSynchronizationContext(); SynchronizationContext.SetSynchronizationContext(syncCtx); // Get the current dispatcher to check thread access. Dispatcher d = Dispatcher.CurrentDispatcher; // Create a FeatureLayer FeatureLayer fl1 = new FeatureLayer { Url = _url, ID = "23", Mode = FeatureLayer.QueryMode.Snapshot, AutoSave = false, }; // Report which thread the FeatureLayer was created on Console.WriteLine("FeatureLayer created on Thread " + d.Thread.ManagedThreadId.ToString()); // Register a handler for the Initialized event fl1.Initialized += (sender, eventArgs) => { // Report which thread the event fired on (this was always a different thread until the DispatcherSynchronizationContext was set Console.WriteLine("Initialized event handled on Thread " + Dispatcher.CurrentDispatcher.Thread.ManagedThreadId.ToString()); // Get the FeatureLayer FeatureLayer fl2 = sender as FeatureLayer; // Get the FeatureLayer dispatcher Dispatcher d1 = fl2.Dispatcher; // Report the thread we're invoking the Update call on (this was always the original thread) Console.WriteLine("Invoking Update on Thread " + d1.Thread.ManagedThreadId.ToString()); // CheckAccess always returned false because this code was running on a different thread until the DispatcherSynchronizationContext was set if (fl2.Dispatcher.CheckAccess()) { fl2.Update(); } else d1.BeginInvoke( DispatcherPriority.Normal, new Action(delegate() { fl2.Update(); })); }; // Register a handler for the UpdateCompleted event and call SaveEdits() fl1.UpdateCompleted += (sender, e) => { // Get the FeatureLayer FeatureLayer fl3 = sender as FeatureLayer; // Get the FeatureLayer Dispatcher Dispatcher d2 = fl3.Dispatcher; // Update the graphic attribute (or perform any other edits) fl3.Graphics[0].Attributes["description"] = Guid.NewGuid().ToString(); // Write out the new value Console.WriteLine( "Updated Graphic ObjectID " + fl3.Graphics[0].Attributes["objectid"] + " with Description: " + fl3.Graphics[0].Attributes["description"]); // Call CheckAccess to confirm whether we need to post back to the original thread // Then call SaveEdits if (fl3.Dispatcher.CheckAccess()) { fl3.SaveEdits(); } else d2.BeginInvoke( DispatcherPriority.Normal, new Action(() => fl3.SaveEdits())); }; // Register a handler for the EndSaveEdits event and write out the status fl1.EndSaveEdits += (sender, e) => { Console.WriteLine(e.Success ? "Success" : "Fail"); // Can check results online at query endpoint (by description value, objectid, etc) // http://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0/query }; // Register a handler for the InitializationFailed event fl1.InitializationFailed += (sender, e) => { // Report error FeatureLayer fl4 = sender as FeatureLayer; Console.WriteLine(fl4.InitializationFailure.Message); }; // Register a handler for the UpdateFailed event fl1.UpdateFailed += (sender, e) => { // Report failure to update layer Console.WriteLine(e.Error); }; // Register a handler for the SaveEditsFailed event fl1.SaveEditsFailed += (sender, e) => { // Report failure Console.WriteLine(e.Error); }; Console.WriteLine("Calling Initialize on Thread " + d.Thread.ManagedThreadId.ToString()); // Call Initialize method (in a map/UI scenario this call would be handled by the Map). fl1.Initialize(); // Need to call Dispatcher.Run Dispatcher.Run(); } } }
