Vince has already mentioned that you can do that by either mapping to a headless dbms account, or make one or two people data owners. Unless you have active directory logins named Florida, you might consider making a dbms account for loading/owning certain data.The person who exports a table from database 1 to database 2 needs to have data owner permissions.
I want to know if there is any way to use OS authentication and not have the data owners AD name show up in the feature class name.
>Will it always assign the Active Directory user's name to the schema/feature class? The basic model is that the user that creates the feature class "owns" it. SQL Server operates a little bit differently in that several releases ago (SQL Server 2005) they removed the concept of "ownership" as it applies to most database objects. Instead, within a database, there can be one or more namespaces called schemas. When data is created, it is associated with a particular schema. So, you could create a schema called 'Payroll' that housed all your payroll data, and multiple users could have permission to create data on the Payroll schema. John.Smith could create a table on Payroll by specifying the schema name in the create table statement - CREATE TABLE Payroll.Employee. Even though he created the data, he doesn't actually own it. However.... and this is a big however, ArcGIS doesn't support schemas in SQL Server this way. We are working on addressing this in a future release, but right now we are still tied into this concept of ownership - the user who creates the data owns the data.
For example, instead of uspsde.'John.Smith'.roads, we can configure it so that it displays (for example) upssde.Florida.roads?
From Having Trouble Getting Data Creators Group to Function Properly the statement "If using a DBO schema geodatabase, only users, or groups which assign user's sysadmin rights within the SQL Server instance will be able to create data." is confusing. We desire that all objects are in the dbo schema, and DO Not want fred.roads and tim.roads. In addition, only DBO's (a very few) are authorized to create objects (feature classes, etc..) and edit them (add columns). Is there ESRI documentation that supports that in order to effect that, the dbo must also be sysadmin? This conflicts with IT security requirements, which strictly limit the sysadmin role.
