How can I add features to a basemap and then convert that features into geodatabase file without using online service ? I am unable to understand the exact procedure. I am working for a disconnected environment. Should i draw graphics on the map and then convert into features ? or we can directly add features and create a geodatabase?MBranscomb-esristaffakajanus-esristaffmnielsen-esristaff
Thanks in advance
It depends on what you are trying to do with this offline feature. Do you just want something you can persist offline? Or are you trying to create features that you want to send back to your enterprise geaodatabase
Sir, I am new to this SDK , Can you help me with both the ways i.e persisting offline( creating a geodatabase offline ) and by using enterprise geodatabase ?
Have you worked through all the samples. The development team has put together a great set of sample code on-line and you can download the entire sample code from github.
Sample Code—ArcGIS Runtime SDK for .NET Samples | ArcGIS for Developers
Here is an example of creating an offline geodatabase
Generate geodatabase—ArcGIS Runtime SDK for .NET Samples | ArcGIS for Developers
and edit and sync
Edit and sync features—ArcGIS Runtime SDK for .NET Samples | ArcGIS for Developers
Hi , sir I have gone through the sample , but in the code , it uses online
feature service to generate the geodatabase . . How can this be done
without itnernet connection , or in a complete offline mode ??
Can we add edit features to a .geodatabase offline , without using any feature service ?? in a completely disconnected mode ??MBranscomb-esristaffakajanus-esristaffmnielsen-esristaff?? thanks in advance
