[user@SAF-4 build]$ sudo java -jar app.jar[sudo] password for user: Java version : 1.7.0_04 (Oracle Corporation) amd64Rendering engine : OpenGLStarting serverOS Name: Linux/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/runtimeLauncherappPid=3316onLinuxAppStateDir=Z:/home/user/Desktop/build/mapDataDir=/home/user/Desktop/build/map/cache/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/runtimeLauncher: line 77: /home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/wine/bin/wine64: Permission denied
...Message : Licensing level : standard:standard:0Message : Server version : 10.2.0.3607Message : Server listening on : http://127.0.0.1:50000/8rNPHp/arcgis/restGLX version 1.4Type = MGRSFrame_buffer_OGL::init_ FAILED to create_ FramebufferNameFrame_buffer_OGL::init_ FAILED to create_ FramebufferNameFrame_buffer_OGL::init_ FAILED to create_ FramebufferNameFrame_buffer_OGL::init_ FAILED to create_ FramebufferNameFrame_buffer_OGL::init_ FAILED to create_ FramebufferNameFrame_buffer_OGL::init_ FAILED to create_ FramebufferName... ... ... ... ... ...
[user@SAF-4 bin]$ chmod a+x wine64
[user@SAF-4 build]$ java -jar app.jarJava version : 1.7.0_04 (Oracle Corporation) amd64Rendering engine : OpenGLStarting serverOS Name: Linux/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/runtimeLauncherappPid=4171onLinuxAppStateDir=Z:/home/user/Desktop/build/mapDataDir=/home/cctt1/Desktop/build-carlos-test/staticResources/map/cache/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/binmkdir: cannot create directory `/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/etc/.wine/drive_c/users/user': Permission denied/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/runtimeLauncher: line 50: cd: /home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/etc/.wine/drive_c/users/cctt1: No such file or directorymkdir: cannot create directory `/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/etc/.wine/drive_c/users/cctt1': Permission denied/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/runtimeLauncher: line 64: cd: /home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/etc/.wine/drive_c/users/cctt1/Local AppData: No such file or directory/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/runtimeLauncher: line 77: /home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/wine/bin/wine64: Permission denied
Looks like a permission issue with "user". As user "user", do you have access to create a directory under "/home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/etc/.wine/drive_c/users"?
... Starting server OS Name: Linux /home/user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/runtimeLauncher appPid=4333 onLinux AppStateDir=Z:/home//user/Desktop/build/map DataDir=/home//user/Desktop/build/map/cache /home//user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin wine64: error while loading shared libraries: libwine.so.1: cannot open shared object file: No such file or directory Radio Id Enterprise Wide Identifier
[cctt1@SAF-4 bin]$ locate libwine.so.1 /home//user/Desktop/build/ArcGISRuntime10.2/LocalServer64/bin/wine/lib64/libwine.so.1.0 /home/user/arcgis/runtime_sdk/java10.1.1/ArcGISRuntime10.1.1/LocalServerLx/bin/wine/lib64/libwine.so.1 /home/user/arcgis/runtime_sdk/java10.1.1/ArcGISRuntime10.1.1/LocalServerLx/bin/wine/lib64/libwine.so.1.0
Regarding the FrameBuffer messages when running from Eclipse, I guess the ArcGIS Runtime plugin was not uninstalled and re-installed from 10.2.
I have yet to figure out what's causing the "Frame_buffer_OGL::init_ FAILED to create_ FramebufferName" prints on both eclipse's console or Linux terminal, but at least it's not causing the app to fail to execute.
How did you resolve this issue? I am also getting the same issue.
When i launch my application from eclipse sandbox. it give the same problem.
Starting server
OS Name: Linux
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher
appPid=2478
onLinux
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 3: basename: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 4: dirname: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 13: basename: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 35: tar: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 36: rm: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 46: mkdir: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 50: cd: //etc/.wine/drive_c/users/rdx1417: No such file or directory
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 51: ln: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 62: mkdir: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 64: cd: //etc/.wine/drive_c/users/rdx1417/Local AppData: No such file or directory
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 65: ln: command not found
/home/dsgislnx16.rdx.lgc.com/rdx1417/arcgis/runtime_sdk/java10.2.3/ArcGISRuntime10.2.3/LocalServer64/bin/runtimeLauncher: line 77: wine: command not found
