As far as I can tell it is still an issue in the 10.4 prerelease Java API.
Hi, I have created a add-in for Arcmap that contains a DockableWindow with a panel and a JButton and JTextfield. When I load the DockableWindow my button and textfield are visible and the button behaves as correctly and can be clicked .The textfield is un-useable it will not allow adding text etc. I have ensured that it is editable via the code and I have even tried to force the focus via the code but I'm still unable to use it. I have also tried using a JTextArea with the same result. Here is a sample of the code from the dockablewindow createUI method@Override public Component createUI() { panel = new JPanel(); keywordTF = new JTextField(10); keywordTF.setText("something"); panel.setLayout(new BorderLayout()); panel.add(keywordTF,BorderLayout.NORTH); return panel; }Any help with this would be great.Thanks Shaun
