use <database> select rastercolumn_id from sde.sde_raster_columns where table_name = '[table_name]' select ID from sde.gdb_objectclasses where name = '[table_name]' select layer_id from sde.sde_layers where table_name = '[table_name]' --Recall the three numbers from these queries. Then run the following queries: use <database> delete from sde.sde_table_registry where table_name = '[table_name]' delete from sde.sde_layers where table_name = '[table_name]' delete from sde.gdb_rastercatalogs where objectclassid = [number from above sde.sde_raster_columns query] delete from sde.gdb_objectclasses where Name = '[table_name]' delete from sde.sde_raster_columns where table_name = '[table_name]' delete from sde.sde_geometry_columns where f_table_name = '[table_name]' DROP TABLE <owner>.<table_name> DROP TABLE <owner>.sde_aux_<# from above rastercolumn_id query> DROP TABLE <owner>.sde_bnd_<#> DROP TABLE <owner>.sde_blk_<#> DROP TABLE <owner>.sde_ras_<#> DROP TABLE <owner>.f[number from above sde_layers query] DROP TABLE <owner>.s[number from above sde_layers query]
sderaster �??o delete
SE_stream_execute (-1002) No rows were deleted
Sderaster �??o drop
