Thanks for the reply. Does anyone know how to get a geo pdf from the arcgis server from javascript?
Tammy, are you accessing the default Print service that you can create in ArcGIS Server 10.2.2? I have been messing around with creating a custom print service, which I may still need to do to get some additional text on the map. In doing so, I tested the output pdf and realized that is it in fact a geoPDF. this is the case using when using my print service thru ArcGIS Online too (as AGOL administrator, I set my organization to point to our local service).
To test, save the .pdf and open it in Adobe Reader or Acrobat Pro.
On my mobile device (ipad) I was able to open up in the free Avenza app by using the built in "open in" options of both Safari and Chrome.
I also tested this using some of the samples in Print webmap | ArcGIS API for JavaScript In particular I explored this one, "print webmap" using the "explorer in the sandbox" option. I changed 1) the mapid to one of my own (from ArcGIS Online), 2) the extent and special reference (mine is not the standard web mercator). and 3) I again pointed to my local service). I then test this, and it also came out as a geoPDF. My guess is it would do the same with the Print | ArcGIS API for JavaScript sample, but that will take a bit more testing to get my data and service inserted.
I hope this helps.
-b
(p.s,..IF this does answer the question, please make it as such so others can find it.)
Tammy,
This is available just add some extra parameters. Here is how it works
Printparams.extraParameters = { Georef_info: "True" };
Hi Tammy, did you get this working? I am trying to do the exact same thing, but just starting the process..so trying to sef if it exists first.
How about using Python in a Geoprocessing task?I haven't tried this but I wonder if it would work. You could first use: http://resources.arcgis.com/en/help/main/10.1/index.html#//00s30000006n000000"Convert Web Map to Map Document" Then feed that map document into ArcPy's ExportToPDF:http://resources.arcgis.com/en/help/main/10.1/#/ExportToPDF/00s300000027000000/which looks like it can create GeoPDFs.
