"Controlling graphic quality of the generated image differs for page layout exports versus data frame exports. When exporting a page layout, control image detail by changing the resolution parameter. When exporting a data frame, keep the resolution parameter at its default value, and change the df_export_width and df_export_height parameters to alter image detail. The height and width parameters directly control the number of pixels generated in the export file and are only used when exporting a data frame. Images with larger numbers of pixels will have higher image detail. For most page layout exports, the default parameter values should generate good results and nice looking export images on the first try. For data frame exports, you may need to experiment with the df_export_width and df_export_height values a few times before getting the result you want."
