Please someone should help me. I want to get the building footprints of all the building in a particular polygon bound using. Thanks
Ikenna,
Well this is a basic Spatial Query then You need to use QueryTask and Query classes specifying the polygon that you want to find the building in as the Query.geometry.
See this sample for basic Spatial Query:
Manage results from multiple queries | ArcGIS API for JavaScript 3.22
Thanks for pointing me in the right direction.
Please how do I query the building footprints without calling the services api
<SPAN class="keyword token">var</SPAN> basemap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArcGISDynamicMapServiceLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver3.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FBloomfieldHillsMichigan%2FParcels%2FMapServer" target="_blank">https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>basemap<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// query task and query for parcels</SPAN> app<SPAN class="punctuation token">.</SPAN>qtParcels <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver3.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FBloomfieldHillsMichigan%2FParcels%2FMapServer%2F2" target="_blank">https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer/2</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>qParcels <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// query task and query for landuse </SPAN> app<SPAN class="punctuation token">.</SPAN>qtBuildings <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver3.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FBloomfieldHillsMichigan%2FParcels%2FMapServer%2F0" target="_blank">https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer/0</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
As i do not have the data for my city. I want to be able to get the building footprints in the rendered map.
I don't understand these statements at all... How do expect to do any of this if you do not have data for your city?
First you have to get a specific polygon from your parcels layer. You can use a querytask for this as well if you know an attribute of the parcel you want to use.
Next you use that polygon as the input geometry for your building footprint.
app<SPAN class="punctuation token">.</SPAN>qBuildings <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>qBuildings<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> YOUR_BUILDING_POLYGON<SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>qBuildings<SPAN class="punctuation token">.</SPAN>outFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>qBuildings<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>qBuildings<SPAN class="punctuation token">.</SPAN>outSpatialReference <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>spatialRefernce<SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>qtBuildings<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">.</SPAN>qBuildings<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//work with the results</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
