Hello, i have trouble with ArcGIS Pro and arcpy.
I want to make a feature layer, change his color and finally add him to the current Map
My Problem is, this Syntax work in Python Window in ArcGIS Pro, but not in my selfmade Tool.
Can someone help me.
lyr <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"C:\ArcGIS\Projects\Geologie\local_scene.gdb\aussrtm_Seligenstadt"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"test"</SPAN><SPAN class="punctuation token">)</SPAN>
aprx <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> m <SPAN class="keyword token">in</SPAN> aprx<SPAN class="punctuation token">.</SPAN>listMaps<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> lyr <SPAN class="keyword token">in</SPAN> m<SPAN class="punctuation token">.</SPAN>listLayers<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> <SPAN class="string token">"test"</SPAN><SPAN class="punctuation token">:</SPAN>
sym <SPAN class="operator token">=</SPAN> lyr<SPAN class="punctuation token">.</SPAN>symbology
sym<SPAN class="punctuation token">.</SPAN>renderer<SPAN class="punctuation token">.</SPAN>symbol<SPAN class="punctuation token">.</SPAN>color <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'RGB'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">}</SPAN>
lyr<SPAN class="punctuation token">.</SPAN>symbology <SPAN class="operator token">=</SPAN> sym<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
