What I'm trying to do is the following:I have html text boxes that the user can input the title information and etc. I'm trying to figure out how to pass those text values into the layoutOptions portions of my print dijit templates.For example, I have the following HTML text input box:Map Title:<input type="text" id="mapTitle" />
I can get the value of that field via, document.getElementById('mapTitle').value
I'm not sure how to push that value into the appropriate place in the template code.var printer = new esri.dijit.Print({
map: map,
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task",
templates: [{
label: "Map Only - PDF",
format: "PDF",
layout: "MAP_ONLY",
exportOptions: {
width: 1500,
height: 1400,
dpi: 150
label: "PDF - Layout",
format: "PDF",
layout: "A4 Portrait",
layoutOptions: {
titleText: PASSED IN VALUE,
authorText: PASSED IN VALUE,
copyrightText: PASSED IN VALUE,
scalebarUnit: "Miles",
label: "JPG - Layout",
format: "JPG",
layoutOptions: {
}, dojo.byId("printButton"));
printer.startup();
I tried what I consider the obvious, which is declaring a variable and then passing in the variable:var userMapTitle = document.getElementById('mapTitle').value;
layoutOptions: {
titleText: userMapTitle ,
But, that did not work.Thanks in advance,
