Failed to create the site. Failed to create the folder 'System'. Failed to clear REST cache on one or more server machines. Please check the log for more details.
<Msg time="2012-10-24T08:41:33,546" type="WARNING" code="6695" source="Admin" process="4468" thread="1" methodName="" machine="<host_name>" user="" elapsed="">Failed to reinitialize REST handler. java.lang.IllegalArgumentException: Host name may not be null </Msg>
1. remove underscore from hostname2. use localhost for machine name when creating site.3. make the ArcGIS account local and give it full control to the server directories
I am working with ESRI tech support but not fixed this problem yet. But may be someone can fix with their suggested solutions. Here are their suggestions: 1. remove underscore from hostname2. use localhost for machine name when creating site.3. make the ArcGIS account local and give it full control to the server directoriesI tried all, but didn't work.
Hello again,I am still having problems because I cannot change the domain name (which is part of the hostname). We are beginning a massive project to change the domain name, but I cannot wait until this has been done (12 months maybe).Is there a way I can trick the install NOT to use the FQDN of the server I am installing to?I am going to keep trying things and will post any progress.
