Xander,Thanks for the help! I have 10 years worth of data. Also, after reading the OLS link you provided, I noticed it said that it is not recommended for predicting binary outcomes. My dependent variable is just that: presence (1) or absence (0) of a species. Should I continue to use OLS? What is the best tool in ArcGIS for predicting binary outcomes?Thanks a million!
Is there are a way to perform OLS only on selected records/years from my feature layer? I am trying to analyze species occurrence over time. I have a "Year" field that denotes different years worth of data. I am using ArcGIS 10.1 SP1 on Win7 x64Thanks!
import arcpy, os from arcpy import env ws = "c:/Folder/yourFileGeodatabase.gdb" # change this fcName = "yourFC" # change this # fields in input FC fldYear = "Year" fldID = "yourUniqueIDfieldName" # change this fldDepVar = "Rainfall" # change this: Dependent_Variable fldExpVar = "Temperature;..." # change this: Explanatory_Variables Coefficient_Output_Table = "olsCoefTab" Diagnostic_Output_Table = "olsDiagTab" olsReport = "c:/Folder/OLSreport" # set workspace env.workspace = ws # create unique set of values in Year field fc = ws + os.sep + fcName values = [row[0] for row in arcpy.da.SearchCursor(fc, (fldYear))] uniqueYears = set(values) # loop through the values for year in uniqueYears: # create feature layer for year qDef = "{0} = {1}".format(fldYear,year) fcFL = "Year_{0}".format(year) arcpy.MakeFeatureLayer_management(fc,fcFL,qDef,"#") # perform OLS on feasturelayer fcOLS = "OLS_{0}".format(year) ols = arcpy.OrdinaryLeastSquares_stats(fcFL, fldID, fcOLS, fldDepVar, fldExpVar, "{0}{1}".format(Coefficient_Output_Table,year),"{0}{1}".format(Diagnostic_Output_Table,year),"{0}{1}.pdf".format(olsReport,year))
