Ok. What you want is the connectivity matrix of the network graph and the edge costs. You can generate that by using some VBA that I list below. To use this, add the network dataset to ArcMap. Make sure to change the name of the attribute name (in this case I have it as meters) to the one that is in your data. The run it in the VBA. The immedate window will show the results. You can re-format the debug.print lines (change them to write to a file) as needed. The output will currently look like this:Junction: 1 is adjacent to: 1 junctions. Adjacent Junction: 2 Length 235.7Junction: 2 is adjacent to: 3 junctions. Adjacent Junction: 1 Length 235.7 Adjacent Junction: 4 Length 470 Adjacent Junction: 6287 Length 287.8Regards,Jay SandhuPublic Sub List_Adjacent_Junctions()On Error GoTo eh Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Dim pNLayer As INetworkLayer Set pNLayer = pMxDoc.FocusMap.Layer(0) Dim pND As INetworkDataset Set pND = pNLayer.NetworkDataset Dim pNQ As INetworkQuery Set pNQ = pND Dim pEnumNE As IEnumNetworkElement Set pEnumNE = pNQ.Elements(esriNETJunction) Dim pNEdge As INetworkEdge Set pNEdge = pNQ.CreateNetworkElement(esriNETEdge) Dim pNEFromJunc As INetworkJunction Set pNEFromJunc = pNQ.CreateNetworkElement(esriNETJunction) Dim pNEToJunc As INetworkJunction Set pNEToJunc = pNQ.CreateNetworkElement(esriNETJunction) Dim pNE As INetworkElement Set pNE = pEnumNE.Next Dim pNEJunc As INetworkJunction Set pNEJunc = pNE Dim i As Integer Do Until pNE Is Nothing Debug.Print "Junction: " & pNEJunc.EID & " is adjacent to: " & pNEJunc.EdgeCount & " junctions." For i = 0 To pNEJunc.EdgeCount - 1 'For each connected edge... pNEJunc.QueryEdge i, True, pNEdge 'Get that connected edge pNEdge.QueryJunctions pNEFromJunc, pNEToJunc 'Get To junction of current edge Debug.Print " Adjacent Junction: " & pNEToJunc.EID & " Length " & pNEdge.AttributeValueByName("Meters") 'List the adjacency Next Set pNE = pEnumNE.Next Loop Exit Subeh: MsgBox "Error: " & Err.DescriptionEnd Sub
