I also have a similar issue to this.
It appears when using principal digits, that the offset reference point is either the top or bottom of the principal digits, as opposed to the centroid of the entire label.
Is there a fix or workaround for this? I have two grids on the same map, and the gap between each grid labels is inconsistent when viewed on the left and right sides of the map, despite the the same offset values applying to the whole map.
