I'm writing CGA rules for manholes and pipe lines which connect manholes together. Does anyone have examples of these kind of CGA rule files I can refer to?
Thank you!
Update to this post.... I found a couple errors in the rules, which when encountered made things look really bad.
Here's a fixed version of the Manhole (attached).
Yeah I found it shortly after I asked the question and then deleted my question. What I really want to ask is how I can change the manhole from "offset" to a more symmetrical one? I see there's a "straight" option but that's not what I want. I'm thinking something similar to the offset model but symmetrical.
You can also open and close the section view using the ShowSection toggle.
This one has all measurements as attributes, so your thinner necks and thicker bodies request is just in the Inspector. Attached is PRK, and it is unlocked so you can unzip it with a file zipper, and see what is inside, or you can just apply it as an RPK.
Let me know your feedback,
Chris
Thank you Chris. That'd be great! My manholes have thinner necks and thicker bodies, wasn't sure how to do that either...
I have a good manhole rule. I'm home now, so I will send it to in you in the morning.
