I am running ArcGIS for Desktop 10.3 connecting to a 10.3 server environment and sde database 10.3
i installed ArcGIS_BackgroundGP_for_Desktop 10.3
Ia,
Is the address locator being stored in SDE or in a file folder?
Are you able to provide a screenshot of the tool settings or inputs for the tool?
-Shana
thanks repply.
the address locatorĀ stored in SDE
Locators built with suggestions should be stored in a file folder rather than in a file or enterprise geodatabase, primarily for performance reasons. The error message 001741 shown in the second screen shot is the result of storing the locator with suggestions enabled in a geodatabase. By storing the locator in a file folder you will also be able to make use of the 'number of threads' performance setting. In the next release of ArcGIS Desktop and in the current release of ArcGIS Pro locators stored in a geodatabase is not supported. The best way to share the locator would be to publish the locator stored in the file folder as a geocode services to ArcGIS Server and use the service by making a GIS Server connection to it in ArcMap/ArcCatalog. Other options are to make the geocode service available in your portal if you have Portal for ArcGIS.
