I understand Robert...Can I use it? http://forums.esri.com/thread.asp?c=158&f=2421&t=287068&m=892110Thanks,David
David, Sorry I can't say I'm interested in developing such a specialized widget (to many other thing on my plate). As far as the CAD data if it is not georeferenced than does it even overlay with your data in the correct location?
Thanks Robert, I better explain what I need....I have a geodatabase with plans NOT georeferenced, so they are overlayed ... and I want to build a widget that makes me easy to select which plan I want to see and then show it (and only it) on the map through a definition query...one more thing..Should I use a Spatial Reference? If yes which one should I use? cause plans come from a simple CAD file not georeferenced.David
David, You would not want a widget with a user interface on the screen for this ability to use a definition query on one layer though (at least I would not). You can easily add code like the sample demonstrates to the MapManager.mxml and then you would not have a need for a widget.
David, Nope I don't see much sense in creating a widget for this as one would probably only use a definition query in very limited circumstances.
Faisal, The definition query array needs to have a query string for each layer in the map service even if the query string is just an empty string. Here is a working example. Wait for the states and counties to draw and when you click the button the only state that will draw it's boundary is Washington.<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:esri="http://www.esri.com/2008/ags" layout="absolute" styleName="plain" pageTitle="Definition Query"> <mx:Script> <![CDATA[ private function test():void { var dynLay:ArcGISDynamicMapServiceLayer = myMap.getLayer("Region") as ArcGISDynamicMapServiceLayer; var layerDefArr:Array=new Array(); var qry:String= new String(); qry="OBJECTID=1"; layerDefArr[0] = ""; layerDefArr[1] = ""; layerDefArr[2] = ""; layerDefArr[3] = ""; layerDefArr[4] = ""; layerDefArr[5] = qry; dynLay.layerDefinitions = layerDefArr; dynLay.refresh(); } ]]> </mx:Script> <esri:Map id="myMap"> <esri:extent> <esri:Extent xmin="-122.2" ymin="24.89" xmax="-70.59" ymax="46.92"> <esri:SpatialReference wkid="4326"/> </esri:Extent> </esri:extent> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/> <esri:ArcGISDynamicMapServiceLayer id="Region" name="Region" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer"/> </esri:Map> <mx:Button x="41" y="536" label="Button" click="test()"/> </mx:Application>
<mx:Script> <![CDATA[ private function test():void { var dynLay:ArcGISDynamicMapServiceLayer = myMap.getLayer("Region") as ArcGISDynamicMapServiceLayer; var layerDefArr:Array = new Array(); layerDefArr[5] = "OBJECTID=1"; dynLay.layerDefinitions = layerDefArr; } ]]> </mx:Script>
