# The field you're querying queryfield = "KEY" # Read the file into a list data = text_file.readlines() # Strip the data of trailing newlines cleandata = [x.strip() for x in data] # Put single quotes around each string for SQL-friendliness queryterms = ["'%s'"%x for x in cleandata] # Put ", " between each of the queries comma_sep_terms = ", ".join(queryterms) # Then make the full expression querystring = '"%s" IN (%s)'%(queryfield,comma_sep_terms) # Use the Select tool once gp.Select(input_shapefile,output_dataset,querystring)
all_lines_to_query = [x.strip() for x in in_file.readlines()] first_half = all_lines_to_query[:len(all_lines_to_query)/2] second_half = all_lines_to_query[len(all_lines_to_query)/2:]
# Text files output = "D:\\Subblocks\\SubblocksOutput.txt" # Set overwrite property gp.OverWriteOutput = 1 # Make feature layer gp.MakeFeatureLayer("D:\\SUBBLOCKS.shp", "feature_lyr") # Open output file in read only mode text_file = open(output, "r") # Read the file into a list data = text_file.readlines() # Strip the data of trailing newlines cleandata = [x.strip() for x in data] # Quick function to put the data into SQL syntax querify = lambda st: '"KEY" = \'%s\''%st # Apply that function to all data (transforming each element from "a1" to "KEY" = 'A1') queryterms = map(querify,cleandata) # Put " OR " between each of the queries querystring = " OR ".join(queryterms) # Use the Select tool once gp.Select(input_shapefile,output_dataset,querystring) # Close text file text_file.close() # Free memory del gp
