Below is the first few lines of a script that I am trying to run from a web.page. I have verified that it runs fine from python but seems fail on the first use of gp when run programaticly. At first I thought the AddToolBox method was failing due to an incorrect path but as I said everything runs fine when run directly from python. I tried adding the line "gp.SetProduct("ArcInfo") " before the ToolBoxLoad and now it fails so it seems to be any use of gp. causing issues.This is ArcGIS10 using Python26 and everything ran fine using the same code/scripts on a machine with ArcGIS9.3 and Python25.Any insight would be greatly appreciated as I am officially stumped.
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
gp.AddToolbox("C:/Program Files (x86)/ArcGIS/Desktop10.0/ArcToolbox/Toolboxes/Data Management Tools.tbx")
