var content =feature.getContent(); registry.byId("leftPane").set("content", content);
Hey,I was browsing forum & api without any result to my query, I'd like to get the data from my popup in order to re-use it with an AJAX function. cannot find a way to do it.I'm already moving my popup next to the map so I though it would be easy to get one of the field.I got this part of code from an arcgis tuto var content =feature.getContent(); registry.byId("leftPane").set("content", content);[HTML]<div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>[/HTML]The content properly get into the leftPane DIV but whenever I try to use it another way than this one I got a 'object HTMLDivElement' as result.thanks
popup.getSelectedFeature()
popup.features
var template = new esri.InfoTemplate("","${Status:compare}");
function compare(value, key, data) { var content = "The Status of XYZ is" + data.Status; registry.byId("leftPane").set("content", content); //show in left Pane return content; //show in Popup }
popup = new esri.dijit.Popup({ markerSymbol:popupmarker, fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25])) }, dojo.create("div"));
