Does the Identity Manager work with 10.0 SP1 and above or 10.1 and above? This came from: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm#jssamples/widget_identitymanager.htmlNote: The IdentityManager works with resources from ArcGIS.com and services published using ArcGIS Server 10.1 or greater.This came from: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/new_v25.htmlThe identity manager replaces both. It is now possible to interact with secure services (ArcGIS Server 10.0 SP1 or hosted on ArcGIS.com) with a single line of code.Also, our web mapping application is nested inside of a secured .NET application, with login credentials provided at webpage entry. Is there a way to pass in the .NET credentials to the JS web mapping application to avoid double user authentication (once at initial log in and again at web mapping application log in)?Thanks,Andrew
