private function updateBarriers():void {var listItems:ArrayCollection = new ArrayCollection(); //update the statuses as per the lists if (lstDay.dataProvider.length > 0) {listItems.source = lstDay.dataProvider.toArray(); updateBarrierStatuses("Day", listItems);} if (lstNight.dataProvider.length > 0) {listItems.source = lstNight.dataProvider.toArray(); updateBarrierStatuses("Night", listItems); } if (lstVarying.dataProvider.length > 0) {listItems.source = lstVarying.dataProvider.toArray(); updateBarrierStatuses("Varying", listItems);} if (lstBarrierNames.dataProvider.length > 0) {listItems.source = lstBarrierNames.dataProvider.toArray(); updateBarrierStatuses("Not Set", listItems);} doShowAllBarriersQuery(); listItems = null; } private function updateBarrierStatuses(barrierType:String, items:ArrayCollection):void {//create a variable to store the barrier name strings var barrierNames:String = ""; var i:Number = 0; //for the time being we are only working with 4 statuses. This means there is no need to determine id's at runtime //if we need to implement different barrier statuses for different training areas and these need to be retrieved at run //time then this will need to change! var barrierStatus:Number; switch (barrierType) {case "Day": {for(i = 0; i < items.length; i++) {barrierNames = barrierNames + items.toString() + ","; barrierStatus = 1;} break; } case "Night":{ for(i = 0; i < items.length; i++) { barrierNames = barrierNames + items.toString() + ","; barrierStatus = 2;} break;} case "Varying":{ for(i = 0; i < items.length; i++) { barrierNames = barrierNames + items.toString() + ","; barrierStatus = 3;} break;} case "Not Set":{ for(i = 0; i < items.length; i++) { barrierNames = barrierNames + items.toString() + ","; barrierStatus = 4;} break;} } //end switch //remove the last "," from the list barrierNames = barrierNames.substr(0, barrierNames.length - 1); setBarrierStatusesWS(myTrainingAreaName, barrierNames, barrierStatus);} private function setBarrierStatusesWS(trainingArea:String, barrierNames:String, status:Number):void {myWS.updateBarrierStatus(trainingArea, barrierNames, status);} private function doShowAllBarriersQuery() : void {//empty the barrier layer first. gfxBarriers.clear(); //set up a unique renderer to symbolise the barrier layer // ref:http://resources.esri.com/help/9.3/arcgisserver/apis/flex/help/index.html#renderers.htm# var uniqueValuerenderer:UniqueValueRenderer = new UniqueValueRenderer(); uniqueValuerenderer.attribute = "cawdapt_dev.CAWDAPT.Barriers.BARRIER_STATUS_ID"; var uniqueValueInfos:Array =[]; uniqueValueInfos.push(new UniqueValueInfo(daySymbol, "1")); uniqueValueInfos.push(new UniqueValueInfo(nightSymbol, "2")); uniqueValueInfos.push(new UniqueValueInfo(varySymbol, "3")); uniqueValuerenderer.infos = uniqueValueInfos; gfxBarriers.renderer = uniqueValuerenderer; allBarriersQuery.where = " cawdapt_dev.CAWDAPT.Barriers.BARRIER_STATUS_ID <> 4"; queryTask.execute( allBarriersQuery, new AsyncResponder(onResult, onFault )); function onGetBarrierResult( featureSet:FeatureSet, token : Object = null ) : void {var displayFieldName : String = featureSet.displayFieldName; for each ( var myGraphic : Graphic in featureSet.features ) {myGraphic.toolTip = "Barrier: " + myGraphic.attributes["cawdapt_dev.CAWDAPT.Barriers.BARRIER_NAME"] + "." ; gfxBarriers.add( myGraphic );} //zoom to full extent of map: var graphicProvider:ArrayCollection = gfxBarriers.graphicProvider as ArrayCollection; var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(graphicProvider.toArray());} function onGetBarrierFault( info : Object, token : Object = null ) : void {Alert.show( info.toString() );} } <!--Web service results handling:--> <esri:QueryTask id="queryTask" url="http://lmgis02/ArcGIS/rest/services/Barriers/MapServer/0" useAMF="false"/> <esri:Query id="allBarriersQuery" returnGeometry="true"> <esri:outFields> <fx:String>CAWDAPT_DEV.CAWDAPT.BARRIERS.BARRIER_NAME</fx:String> <fx:String>CAWDAPT_DEV.CAWDAPT.BARRIERS.BARRIER_STATUS_ID</fx:String> <fx:String>CAWDAPT_DEV.CAWDAPT.BARRIER_STATUSES.BARRIER_SYMBOL</fx:String> <fx:String>CAWDAPT_DEV.CAWDAPT.BARRIER_STATUSES.SYMBOL_COLOUR</fx:String> </esri:outFields> </esri:Query> <mx:TabNavigator width="100%" height="95%" x="0" y="0"> <mx:Canvas label="Set Barriers" width="100%" height="100%" backgroundColor="#D8D8D8"> <s:VGroup> <mx:HRule width="100%" height="3"/> <s:HGroup id="BarriersGroup"> <s:VGroup> <s:Label id="lblName" text="Barrier Name" toolTip="You can select multiple items by holding CTRL key and clicking, or select a block by holding shift key and clicking"/> <s:List id="lstBarrierNames" dragEnabled="true" dropEnabled="false" allowMultipleSelection="true" dragMoveEnabled="true" dataProvider="{barrierNameArray}" styleName="ListControl" skinClass="Landmarc.customSkins.BarrierListSkin" /> </s:VGroup> <s:VGroup> <s:Label id="lblDay" text="Day" toolTip="Drag and Drop Barriers open during the day into this column"/> <s:List id="lstDay" dragEnabled="true" dropEnabled="true" allowMultipleSelection="true" dragMoveEnabled="true" dataProvider="{new ArrayCollection([])}" styleName="ListControl" skinClass="Landmarc.customSkins.BarrierListSkin"/> </s:VGroup> <s:VGroup> <s:Label id="lblNight" text="Night" toolTip="Drag and Drop Barriers open at night into this column"/> <s:List id="lstNight" dragEnabled="true" dropEnabled="true" allowMultipleSelection="true" dragMoveEnabled="true" dataProvider="{new ArrayCollection([])}" styleName="ListControl" skinClass="Landmarc.customSkins.BarrierListSkin" /> </s:VGroup> <s:VGroup> <s:Label id="lblVary" text="Varying" toolTip="Drag and Drop Barriers open at varying times into this column"/> <s:List id="lstVarying" dragEnabled="true" dropEnabled="true" allowMultipleSelection="true" dragMoveEnabled="true" dataProvider="{new ArrayCollection([])}" styleName="ListControl" skinClass="Landmarc.customSkins.BarrierListSkin"/> </s:VGroup> </s:HGroup> <mx:HRule width="100%" height="3"/> <s:Button label="Save barriers statuses" click="updateBarriers()"/> </s:VGroup> </mx:Canvas>
