Can you share a URL to your map so we can take a look?Layer ordering is a bit tricky in web maps. Some layers can't be drawn on top of others. For example, any map notes, CSVs, shapefiles added to the map can't be moved under a layer from a map service. So maybe the software is making you think that it can, which would be a bug, but then when you open the map again, the layers are drawn as the system can support.Thanks,Mike
