What raster format are you outputting to? Have you tried .tif or .img? If you are outputting to an Esri GRID, I have seen this issue, but never been able to reproduce it in house. The floating profiles in academic institutions seem to be part of the issue, I would also recommend trying to move the working directory to a local location as well for the processing. I also assume that you have made the necessary changes in the syntax for Raster Calculator to work.
I experienced similar situation when multiplying two binary raster (same extent, same cell size). The result seems odd as there are cells with negative value (e.g., -21414). I am wondering whether this is a function error associated with ArcGIS 10.1 and whether your problem has been solved. Thank you.
No solution. Continues to be unstable. We frequently see the results with larger negative numbers from a raster calculator function - no error message, but clearly incorrect results. We have seen this particular problem for several years, not just ArcGIS 10.1. If we use the 'multiply' tool instead of raster calculator when we have this happen, it works correctly.
I have a mask of the smaller area composed of 1's where I want to keep values and NODATA in the background. (the mask is a single USGS quad sheet, the LULC is for an entire watershed). I use raster calculator to multiply the mask * LULC. The output is subset to the extent of the mask, but it is assigned a value of zero for all pixels where the mask has values of 1.
