Hi,At Prerelease the new accelerated display functionality is dependent on having the DirectX End User Runtime installed. ...There is some more information on this in the release notes: http://resourcesbeta.arcgis.com/en/help/runtime-wpf/concepts/index.html#/Release_notes_ArcGIS_Runtime_SDK_1_0_Prerelease_for_WPF/01700000006s000000/
Sample: LocalAcceleratedMap Error: Accelerated Display failed to create. Please check DirectX end user runtime is installed. Also check the graphics drivers support Windows Display Driver Model (WDDM), note that standard VGA drivers do not support WDDM. Stack Trace: at ESRI.ArcGIS.Client.NativeMap..ctor() at ESRI.ArcGIS.Client.DrawingSurface.CreateRenderSurface() at ESRI.ArcGIS.Client.Map.OnApplyTemplate() at System.Windows.FrameworkElement.ApplyTemplate() at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.Controls.Grid.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint) at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.Controls.Border.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.Controls.Control.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint) at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.ContextLayoutManager.UpdateLayout() at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg) at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork() at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks() at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget) at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler) Sample: LocalAcceleratedMap Error: Object reference not set to an instance of an object. Stack Trace: at ESRI.ArcGIS.Client.DrawingSurface.SetSize(Int32 width, Int32 height) at ESRI.ArcGIS.Client.Map.<Map_SizeChanged>b__d() at ESRI.ArcGIS.Client.ThrottleTimer.<.ctor>b__1(Object s, EventArgs e) at System.Windows.Threading.DispatcherTimer.FireTick(Object unused) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
