Hello!
I'm trying interpolate surface using point shapefile, but ArcMap crashed on interpolation. I checked and able to do it using predefined Arctoolbox scripts, so data is ok.
I use ArcGIS 10.1 SP1, Spatial Extension, MS Visual Studio 2012, .Net Framework 4.
Does anyone can help in it?
public void InterpolateTest()
IFeatureClass fcClass01 = default(IFeatureClass);
fcClass01 = GetFeatureClass(); // see below
// Create FeatureClassDescriptor using a value field.
IFeatureClassDescriptor fcDescr = default(IFeatureClassDescriptor);
fcDescr = new FeatureClassDescriptor() as IFeatureClassDescriptor;
fcDescr.Create(fcClass01, null, "gdsA");
// Create Input geodataset
IGeoDataset gd = fcClass01 as IGeoDataset;
// Create Output geodataset
IRaster rasOut = default(IRaster);
IInterpolationOp2 interpOp = default(IInterpolationOp2);
interpOp = new RasterInterpolationOp() as IInterpolationOp2;
//try to interpolate - crash on this line
rasOut = (IRaster)interpOp.NaturalNeighbor(gd);
public ESRI.ArcGIS.Geodatabase.IFeatureClass GetFeatureClass()
ESRI.ArcGIS.Geodatabase.IWorkspaceFactory workspaceFactory = new ESRI.ArcGIS.DataSourcesFile.ShapefileWorkspaceFactory();
String string_RasterWorkspace = "C:\\temp\\";
String string_ShapefileName = "dis.shp";
ESRI.ArcGIS.Geodatabase.IWorkspace workspace = workspaceFactory.OpenFromFile(string_RasterWorkspace, 0);
ESRI.ArcGIS.Geodatabase.IFeatureWorkspace featureWorkspace = (ESRI.ArcGIS.Geodatabase.IFeatureWorkspace)workspace; // Explict Cast
ESRI.ArcGIS.Geodatabase.IFeatureClass featureClass = featureWorkspace.OpenFeatureClass(string_ShapefileName);
FeatureClass fc = featureClass as FeatureClass;
return featureClass;
