I used the javascript found at test-cors.org and built this little test page. Hopefully this will do. I'm not sure yet if it captures every possibility but it will work as a start. Does anyone have anything more elegant?
<html> <head> <title>Test for CORS</title> <script type="text/javascript"> //Modified from the code found at test-cors.org function testcors(url){ var createCORSRequest = function(method, url) { var xhr = new XMLHttpRequest(); if ("withCredentials" in xhr) { // Most browsers. xhr.open(method, url, true); } else if (typeof XDomainRequest != "undefined") { // IE8 & IE9 xhr = new XDomainRequest(); xhr.open(method, url); } else { // CORS not supported. xhr = null; } return xhr; }; var method = 'GET'; var xhr = createCORSRequest(method, url); xhr.onload = function() { // Success code goes here. thendothis(true); }; xhr.onerror = function() { // Error code goes here. thendothis(false); }; xhr.send(); //return iscors; } function thendothis(iscors){ var resptxt = "No"; if (iscors) { resptxt = "Yes"; } document.getElementById("res").innerHTML = resptxt; } function runtest(frm){ testcors(frm.url.value); } </script> </head> <body> <form> URL: <input type="text" name="url" id="url" style="width:500px" /></br> <input type="button" value="Test if CORS" onclick="runtest(this.form)" /> </form> <div>URL is CORS: <span id="res"></span></div> </body> </html>
