Thank you for the reply. I am getting off work now, so I will try to wing it again in the morning. I am using model builder and the join would fail saying that they have to be the same type. That is where I am getting the problem. It Will run for 5 minutes or so before it tells me that.
Use a standard ArcMap join on a field. There are several ways to set it up. For layers I often right click the layer in the Table of Contents, choose Joins and Relates, and choose Join to bring up the Join dialog. In the Join dialog I choose the field from my layer that is related to another table, then I choose that other table and the field in that other table that matches. Then I press OK and the fields from he Join table appear in the table view of my layer. When you are done with the join you right click the layer, choose Joins and Relates, choose Remove Join(s), and choose Remove All.
From within a Table View a Join can be set up by expanding the Table Options button (ArcMap 10.0 and above), and then using the same menu options that are available from the Layers context menu.
The Geoprocessing tool equivalent is the Join tool and the Remove Join tool (for when you are done with the Join).
How would you join it back to the original. It is now a standalone table?
I have a set of polygons that have been dissected into sub-polygons to reflect spatial values. I need to select the spatial value of the largest sub-polygon to use to describe the entire polygon. I thought Dissolve would work, but it does not always return the spatial value for the largest polygon. Here is an example of the table: Name Acres ValueLoc1 1.0 MLoc1 2.0 NLoc1 0.5 P I need to be able to assign Value N to the Loc1 polygon (dissolved on 'Name') because the largest sub-poly value is N. I've tried various Dissolves, Selects, etc. but cannot get a file with the correct values. I also really can't use grid files because the area of the polygon needs to remain consistent.
