Ik heb een REST-service.
Laag: Wegafsluitingen (ID: 0)
Ik heb er een AGOL-laag van gemaakt.
http://cityoftulsa.maps.arcgis.com/home/item.html?id=890d36b5d70d4199b22a867d9f927d1c#overview
Maar nu... om de een of andere reden... kan ik de symbolisatie (of visualisatie) van die laag en van alle lagen die daarop zijn gebaseerd niet meer aanpassen.
In Chrome INSPECT krijg ik het volgende:
Uncaught Error<SPAN class="punctuation token">:</SPAN> dojox<SPAN class="punctuation token">.</SPAN>data<SPAN class="punctuation token">.</SPAN>AndOrWriteStore<SPAN class="punctuation token">:</SPAN> Ongeldig itemargument<SPAN class="punctuation token">.</SPAN>
at Object<SPAN class="punctuation token">.</SPAN>_assertIsItem <SPAN class="punctuation token">(</SPAN>base<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">795</SPAN><SPAN class="punctuation token">)</SPAN>
at Object<SPAN class="punctuation token">.</SPAN>getValues <SPAN class="punctuation token">(</SPAN>base<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">796</SPAN><SPAN class="punctuation token">)</SPAN>
at Object<SPAN class="punctuation token">.</SPAN>getValue <SPAN class="punctuation token">(</SPAN>base<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">796</SPAN><SPAN class="punctuation token">)</SPAN>
at Object<SPAN class="punctuation token">.</SPAN>clean <SPAN class="punctuation token">(</SPAN>arcgisonline<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">5249</SPAN><SPAN class="punctuation token">)</SPAN>
at Object<SPAN class="punctuation token">.</SPAN><SPAN class="operator token"><</SPAN>anonymous<SPAN class="operator token">></SPAN> <SPAN class="punctuation token">(</SPAN>arcgisonline<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">9646</SPAN><SPAN class="punctuation token">)</SPAN>
at dojo<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">44</SPAN>
at Object<SPAN class="punctuation token">.</SPAN>fetchItemByIdentity <SPAN class="punctuation token">(</SPAN>base<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">809</SPAN><SPAN class="punctuation token">)</SPAN>
at Object<SPAN class="punctuation token">.</SPAN>getAttributeItem <SPAN class="punctuation token">(</SPAN>arcgisonline<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">9646</SPAN><SPAN class="punctuation token">)</SPAN>
at Object<SPAN class="punctuation token">.</SPAN>updateUIWithRenderer <SPAN class="punctuation token">(</SPAN>arcgisonline<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">9321</SPAN><SPAN class="punctuation token">)</SPAN>
at Object<SPAN class="punctuation token">.</SPAN>_init <SPAN class="punctuation token">(</SPAN>arcgisonline<SPAN class="punctuation token">.</SPAN>js<SPAN class="punctuation token">:</SPAN><SPAN class="number token">9307</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Ik begrijp totaal niet waarom dit gebeurt. Ik heb geprobeerd de eigenaar, het deelniveau enzovoort te wijzigen. De laag is momenteel 100% openbaar... Ik snap er niets van.
