Hello CE Community,
I'm looking for a way to override randomized textures. It would be nice to have the ability to change the textures with a drop-down menu in the inspector.
Thanks.
Yes, that is correct. The @File annotation allows you to open a file chooser.
Annotations—ArcGIS CityEngine Resources | Documentation
I think you are trying to activate browse tool.
I use the texture folder wildcard method:
attr wall_tex = getWallTexture getWallTexture = listRandom(_getWallTexture) _getWallTexture = fileSearch("/FolderDestination*" + "*.*") <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Then over in the inspector you should be able to access the "browse" to override your texture:
I also think you can activate the browse by simply adding the "@File" before your attribute rule (?).
Just use a stochastic rule in your attribute. This will randomize on seed generation and then give you the ability to change it. Something like the code below should work.
@Enum("texA.jpg","texA.jpg","texC.jpg","texD.jpg") attr Texture = 25%: "texA.jpg" 25%: "texB.jpg" 25%: "texC.jpg" else: "texD.jpg"<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
