What kind of data did you export? Anything you display over Esri basemaps is shown in Web Mercator Auxillary Sphere. Are you talking about using the measure tool?Thanks,Mike
Unfortunately, with a public account, you can't control the coordinate system when uploading a zip file of your data. You get Web Mercator Auxiliary Sphere so it can display over the basemaps.With a subscription to ArcGIS Online, you can publish your data in your desired coordinate system.Thanks,Mike
Yes, you can create a web service out of your data, either a hosted feature service, a hosted tiled map service or both. Alternatively, if you have ArcIGS Server, you can publish services to your own server.http://resources.arcgis.com/en/help/arcgisonline/#/What_are_ArcGIS_Online_hosted_services/010q0000007z000000/Here's how to publish from ArcMap:http://resources.arcgis.com/en/help/arcgisonline/index.html#//010q00000087000000Note that publishing your data in UTM will mean that you will not be able to display your data over the default basemaps that are part of ArcGIS Online. These are in Web Mercator Auxiliary Sphere. When you author your web maps, you will need to check the option to make your data the basemap.Hope this helps.Mike
