I can't seem to access anything map related!The same scripts work perfectly in the Python window in ArcMap (an example below), but run as a py script = nothing.Code:import arcpyimport ctypesmxd = arcpy.mapping.MapDocument("CURRENT")nam = mxd.activeDataFrame.namectypes.windll.user32.MessageBoxA(0, nam, "Dialog Title", 1)Are there any limitations or approaches I should be aware of?
Hi Bjorn,Sadly that makes sense - I thought I was perhaps asking too much of it. Would you be able to point me in the right direction on what information I need to pass in about the environment to a script? I'm assuming I need to pass this information as parameters.Most (but not all) of our data is contained in an MPK file loaded into the application - could I somehow point the script to the same MPK file?Thanks for your help.Gary
