I have a text field with date values in YYYYMMDD format. I need to get them into the MM/DD/YYYY format in a text field (the target field for the MM/DD/YYYY values is text, not date). The source field containing the YYYYMMDD values is named 'LastUpdateDate' and the target for the MM/DD/YYYY values is named 'CAMAUpdate'. I'm attempting to use this:
SUBSTRING(!LastUpdateDate!,4,5)+'/'+SUBSTRING(!LastUpdateDate!,6,7)+'/'+SUBSTRING(!LastUpdateDate!,0,3)<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
In Pro 2.6.2 it fails with:
ERROR 000539: Traceback (most recent call last):
File "<expression>", line 1, in <module>
NameError: name 'SUBSTRING' is not defined
Source data is a polygon feature class in a file geodatabase.
