<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title> </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ padding:0; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script> <script type="text/javascript"> dojo.require("dijit.dijit"); // optimize: load dijit layer dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); //dojo.require("esri.virtualearth.VETiledLayer"); dojo.require("dijit.TitlePane"); dojo.require("esri.dijit.BasemapGallery"); dojo.require("esri.arcgis.utils"); function init() { var initExtent = new esri.geometry.Extent({ "xmin": -11727455, "ymin": 4861652, "xmax": -11706340, "ymax": 4871512, "spatialReference": { "wkid": 102100} }); var _map = new esri.Map("map", { extent: initExtent }); var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); _map.addLayer(initBasemap); //Programmatic 2 - will produce empty //add bmg to programmatic contentpane _tp1 = new dijit.TitlePane({ title:"Programmatic 2", open: false }); basemapGallery3 = new esri.dijit.BasemapGallery({ showArcGISBasemaps: true, map: _map }, dojo.create("div")); basemapGallery3.startup(); // _tp1.setContent(_c1); _tp1.placeAt(dijit.byId("leftside").containerNode); _tp1.setContent(basemapGallery3.domNode); //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', _map, _map.resize); } //show map on load dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="sidebar" gutters="false" style="width:100%;height:100%;margin:0;"> <div id="leftside" dojotype="dijit.layout.ContentPane" region="left" style="width:200px;border:1px solid #000;padding:0;"> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"> </div> </div> </body> </html>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title> </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ padding:0; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script> <script type="text/javascript"> dojo.require("dijit.dijit"); // optimize: load dijit layer dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); //dojo.require("esri.virtualearth.VETiledLayer"); dojo.require("dijit.TitlePane"); dojo.require("esri.dijit.BasemapGallery"); dojo.require("esri.arcgis.utils"); //var map = null; function init() { var initExtent = new esri.geometry.Extent({ "xmin": -11727455, "ymin": 4861652, "xmax": -11706340, "ymax": 4871512, "spatialReference": { "wkid": 102100} }); var _map = new esri.Map("map", { extent: initExtent }); var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); _map.addLayer(initBasemap); //add bmg to declarative contentpane html (existing) var basemapGallery1 = new esri.dijit.BasemapGallery({ showArcGISBasemaps: true, map: _map }, "Div4"); basemapGallery1.startup(); //Programmatic 1 - will produce ID registry error //add bmg to declarative titlepane html (existing) // var basemapGallery2 = new esri.dijit.BasemapGallery({ // showArcGISBasemaps: true, // map: _map // }, "Div1"); // basemapGallery2.startup(); //Programmatic 2 - will produce empty //add bmg to programmatic contentpane var _tp1 = new dijit.TitlePane({title:"Programmatic 2"}); var _c1 = new dijit.layout.ContentPane({id:"c1",style:"background-color:lightblue;"}); var basemapGallery3 = new esri.dijit.BasemapGallery({ showArcGISBasemaps: true, map: _map }, "c1"); basemapGallery3.startup(); _tp1.setContent(_c1); _tp1.placeAt(dijit.byId("leftside").containerNode); //Programmatic 3 - will produce ID registry error //add bmg to programmatic contentpane // var _tp2 = new dijit.TitlePane({ title: "Programmatic 3" }); // var basemapGallery4 = new esri.dijit.BasemapGallery({ // showArcGISBasemaps: true, // map: _map // }, _tp2); // basemapGallery4.startup(); // _tp2.placeAt(dijit.byId("leftside").containerNode); //Programmatic 4 - will produce empty //add bmg to programmatic contentpane var _tp3 = new dijit.TitlePane({ title: "Programmatic 4" }); _tp3.placeAt(dijit.byId("leftside").containerNode); var basemapGallery5 = new esri.dijit.BasemapGallery({ showArcGISBasemaps: true, map: _map }, _tp3.srcNodeRef); basemapGallery5.startup(); //Programmatic 5 - will produce empty "flowcontainer" //add bmg to programmatic contentpane var _tp4 = new dijit.TitlePane({ title: "Programmatic 5" }); _tp4.placeAt(dijit.byId("leftside").containerNode); var basemapGallery6 = new esri.dijit.BasemapGallery({ showArcGISBasemaps: true, map: _map }); basemapGallery6.startup(); _tp4.setContent(basemapGallery6); //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', _map, _map.resize); } //show map on load dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="sidebar" gutters="false" style="width:100%;height:100%;margin:0;"> <div id="leftside" dojotype="dijit.layout.ContentPane" region="left" style="width:200px;border:1px solid #000;padding:0;"> <div dojoType="dijit.TitlePane" id="Div3" title="Declarative Basemap" closable="false" open="false"> <div id="Div4"></div> </div> <div dojoType="dijit.TitlePane" id="Div1" title="Programmatic 1 Basemap" closable="false" open="false"> </div> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"> </div> </div> </body> </html>
