is it all features in the FC that vanish? or just one? I've encountered this problem in a couple of situations.The first is for very small features that are being displayed at scales of 1:50 or greater, and i think an ESRI support technician indicated this was a bug though it sounds as if this isn't your problem exactly.Another issue i've encountered that seems to cause polygon features to vanish has to do with the order/direction of vertices in the polygon. I think that generally ArcGIS likes polygons to be created in a clockwise fashion so that the index value of vertices increase from 1 to n as you proceed clockwise around the perimeter of a polygon. If you throw in a polygon that has its vertices ordered in the opposite direction this can cause some issues. Problems I've encountered that seem symptomatic of this issue include:Polygons vanishing when zooming or panningPolygon fills being applied to the region 'outside' the polygonNegative values being returned when calculating feature areasMainly I find this is an issue with polygons that have been manually digitized or when polygons have been created with a GPS unit and the field people have traversed the boundary in an counter-clockwise fashion. I know it seems weird, but every time I have encountered this issue and inspected the problematic polygons they have been created in reverse order, and recreating them so that they are 'clockwise' polys always fixes the problem.One way to check this is to start an edit session on your polygons, select and double click a polygon to activate the 'edit vertices' tool, hover your cursor over a vertex as if you were going to move it, then right click and select 'sketch properties' - this will pop up a box that lists the vertices as an ordered list. If you select them one after the other in order, you'll be able to see if the vertices are ordered in clockwise or counter clockwise fashion. There I'm not sure if the geometry repair tools fix this problem or not, but I can see where this is a pain if you have many polygons to edit.I'm not sure if this is a bug or a 'feature' and the product is working as intended by ESRI developers.
