<script type="text/javascript"> dojo.require("dijit.dijit"); dojo.require("dijit.dijit-all"); dojo.requireLocalization("esriTemplate","template"); </script> <script type="text/javascript" src="javascript/layout.js"> </script> <script type="text/javascript"> var configOptions; function init() { var webmap = {}; webmap.item = { "title":"Soil Survey Map of USA", "snippet": "This map shows the Soil Survey Geographic (SSURGO) by the United States Department of Agriculture's Natural Resources Conservation Service.", "extent": [[-139.4916, 10.7191],[-52.392, 59.5199]] }; webmap.itemData = { "operationalLayers": [{ "url": "http://server.arcgisonline.com/ArcGIS/rest/services/Specialty/Soil_Survey_Map/MapServer", "visibility": true, "opacity": 0.75, "title": "Soil Survey Map", "itemId": "204d94c9b1374de9a21574c9efa31164" }], "baseMap": { "baseMapLayers": [{ "opacity": 1, "visibility": true, "url": "http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer" },{ "isReference": true, "opacity": 1, "visibility": true, "url": "http://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Reference_Overlay/MapServer" }], "title": "World_Terrain_Base" }, "version": "1.1" }; configOptions = { //The ID for the map from ArcGIS.com //webmap:"dbd1c6d52f4e447f8c01d14a691a70fe", webmap:webmap, //The id for the web mapping applciation item that contains configuration info - in most //cases this will be null. appid:"", //set to true to display the title displaytitle:true, //Enter a title, if no title is specified, the webmap's title is used. title:"", //Enter a description for the application. This description will appear in the left pane //if no description is entered the webmap description will be used. description: "", //Specify a color theme for the app. Valid options are gray,blue,purple,green and orange theme:'gray', //Optional tools - set to false to hide the tool //set to false to hide the zoom slider on the map displayslider:true, displaymeasure:true, displaybasemaps:true, displayoverviewmap:true, displayeditor:true,////When editing you need to specify a proxyurl (see below) if the service is on a different domain //Specify a proxy url if you will be editing proxyurl: "http://autumn/proxy/proxy.ashx", displaylegend:true, displaysearch:true, displaylayerlist:true, displaybookmarks:true, ....... more config stuff here }; initMap(); } dojo.addOnLoad(init); </script>
