Is it possible to remove the Widget header controls for some widgets or the map?
Specifically, I would like to remove the div which includes the widget title, maximise & close buttons. This is for WAB 2.7.
Thanks!
Baker,
You can use a CSS rule to hide those.
Here is a sample rule for hiding the title, close, minimize, etc on widget _5.
<SPAN class="selector token">#_5_panel.jimu-panel>.jimu-panel-title>.title-label</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">#_5_panel.jimu-panel>.jimu-panel-title>.close-btn</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">#_5_panel.jimu-panel>.jimu-panel-title>.max-btn</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">#_5_panel.jimu-panel>.jimu-panel-title>.foldable-btn</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
